Sexy packages.
Odd huge packaging for a CPU with no cooler.
HD Graphics 530?Sound like a massive downgraded over HD Graphics 4400.
Intel should called it HD Graphics 6300!
has there been much listed about the speed of m.2 on these new motherboards?
i see some have 2x m.2 slots but i would like to know the speed
are they still going to be very limited on lanes?
They should be full speed m.2 slots well at least one as the skybridge cpus come with 20 lanes. So 16x for a single GPU or 8x 8x for dual GPU setup which leaves you with 4 lanes for a m.2 unless you use both m2. slots then they may run at 2x each which will make them run at slower speeds. Not sure why there are two slots on the motherboards as id rather get a bigger single m2 SSD than two smaller ones.
I linked a z170 mATX above
Here is an EVGA one for X99:
http://fudzilla.net/news/motherboards/38368-evga-launches-new-x99-micro2-motherboard
M.2 and USB 3.1 type c
Is there any downside to Skylake's implementation in comparison to 28/40 coming from the CPU on Haswell-E?
Sure. None CPU adds big latency.
Will an average, day-to-day user/gamer notice the 'big latency'? Would it still perform better than a conventional SATA III SSD?
Skylake has 36 PCI-E V3 lanes. Only 16 from the CPU, for GPU's/other PCI-E cards, and then another 20 from the chipset, for M.2/Sata express and other things etc.
I'd be grateful if you'd let me know - Mulling over an entire rebuild and I am not too sure which road to go down.
