Clean install of windows 10 .... Grrrrr
5 Jun 2005
Southampton
Ok so updated 8.1 pro to windows 10. I purchased a new ssd for windows 10, so pulled my main ssd and started the install of windows 10 from the downloaded ico as others have said I could do.
Windows 10 installed as home version and I can't activate.
Any ideas ? I thought the activation link was to the mobo ?
How did you managed to install 10 Home?
It won't activate as your machine has a 10 Pro license if it went from 8.1 Pro. You need to install 10 Pro and you will be good.
Yes, you have an option for Home or Pro to download as an ISO unless you chose to 'Upgrade this PC' as that will download and install the correct one for you.
Obviously you know that you have to download the one that is compatible to the OS you have now. More info here
Ok doing that now. I must have just clkcked next. Just confusing with some of these posts saying to download the pro version.
Thats ok. Just download the version that is compatible to the OS you are using now. For me, i was running just ordinary 8.1 so i had to select Win 10 Home edition.
