This seems to be the last website that I use regularly that is still on http. Do we know if there are plans to move to the more secure https? Or am I missing something obvious?
I don't think you realise the difference between HTTP and HTTPS and they are used for.
What ? Most websites are not https. What are you talking about ?
You can force HTTPS everywhere with an EFF plugin, called, coinkidinkly, HTTPS everywhere. So it'll use HTTPS just for regular browsing if it's available. I do. Because Snowden.
So long as login details are sent https
But they aren't.
We need to setup a MITM.
OH NOES TEH PUBLIC INTRENETS FORUM ISNT SECURES!!1112
Don't you just love it when you hear acronym speak...![]()
Considering Google now rank sites using SSL higher than without, I think you're struggling to understand the difference..
Sure, in this instance it would be a bit pointless, but it's becoming more commonplace for domains to be using a basic CA signed cert.
