How to migrate Windows 8.1 to SSD from HDD?
24 Jun 2014
Hi, I want to move my Windows installation which is on my HDD currently, to my SSD. As my SSD is smaller in size than my HDD, is there any way I can migrate Windows only, and not my files? Also, how can I remove Windows from my HDD? As I won't be using the installation on there. I need to know how to make my SSD the default boot drive as well.
Thanks
DJL99
I would use this as a good time to do a fresh install of Windows.
Saving all the important files first though.
In your case I'd also recommend doing a fresh install and then later deleting your old OS files from your HDD. If both hard drives have a bootable OS, you'll be presented with a menu on bootup where you can select an OS to use.
As everyone had already advised, a fresh install was led be preferential. Plus then Windows will see its on and SSD and make relevant changes.
Cloning software like the one Lemin suggested.
Or fresh install if you don't mind installing software again, Steam games can easily transferred over.
I didn't bother formatting a new Intel 530 SSD in a system I installed widnows on yesterday and everything went smoothly :)
P.S make sure you disconnect your old HDD before installing windows. You don't want any OS files finding their way on to the old HDD.
I have backed up everything to my external HDD. I have backed up my entire SteamApps folder. Will I be able to move it back into the Steam folder? Will that work, because I don't want to reinstall everything?
you can have your steamapps folder anywhere and just add it back in to steam via adding another library
that's what I did, OS on 1 SSD and games all stored on another with steam installed on C so once steam is installed just link it back to the steam games location on my second SSD
