- 12 Nov 2014
- Westgate On Sea, Kent
I have 2 PC's running of my home network system currently on sky. I have a Lot of Bluray and DVD's stored on my main i5-4690k Processor PC. It currently has 2 x Western Digital Blue Drives at 1TB each and a SSD samsung 850 Pro 256GB with operating system on it.
The first Western Digital Drive D: is where all my programs and Data is Stored and Main use Drive.
The second Western Digital was going to be used as a basic Backup of D: Program and Data files. But Currently Hold my Movies on it full copies on My Blurays and DVDs.
as i find playing from hard Drive much easier than looking for DVD or Bluray from shelves which is difficult when you are disabled and mainly wheelchair bound.
MY GOAL:-
I want to be able to store all my own owned original BLURAY and DVD's all on hard drives and play direct from there. Ihave all software necessary to do this purchased and registered legally.
What kind of storage system can i setup that will allow multiple drives to be connected to network and store all my movies on it and play direct from it from either machine as one in livingroom other in another room and both have main 3d screens and also can play direct to my 3d smart tv by HDMI. have not worked out how to do wireless playing as think i need a certain type of wireless adapter a intel adapter to do miracast as tv is miracast enabled.
What hardware to i need to be able to have several large 1TB or 2TB drives in a case/unit that connects to network by IEEE network cable direct to router or do i connect it direct to PC and use the sata ports that are spare ????.
PC's Motherboard is a Z97X-SLI Gigabyte Motherboard Rev 1.0 ???
Sata0 ,ssd
sata1 , western digital d: main programs and data
sata2 , western digital e: backup data and movies from dvd's and Blu-Ray's
sata3 , akasa card 6 in 1 card reader and usb 2.0
sata4 , LG BH16NS40 Blu-Ray Read/Writer
sata5 and Sata6 not used yet
M.2 connector.
but room for one more external drive possible hot swap hard drive system ???
room for internal drives as well space for 3 drives physically but not enough sata connectors.
only 2 sata connectors free in total.
Chipset:
1 x M.2 PCIe connector
(Socket 3, M key, type 2242/2260/2280 SATA & PCIe SSD support)
1 x SATA Express connector
6 x SATA 6Gb/s connectors
(M.2, SATA Express, and SATA3 4/5 connectors can only be used one at a time. The SATA3 4/5 connectors will become unavailable when an M.2 SSD is installed.)
Support for RAID 0, RAID 1, RAID 5, and RAID 10
So what are my options here to get a lot more storage for keeping my movies on and considering that some movies take the 45gb that a bluray actually hold. states 50gb dual layer but checked and only 45 available in reality. ??
So need a lot of storage and hot swap capability so when i get to point of running out of room on what ever setup is used i can always hotswap a hard drive. its easier to just hot swap one drive that could contain approximately only 20 movies of full blu-ray standard to one western digital blue 1TB.
Could contain app. 30 in theory per 1tb hard drive but that's not a lot considering amount of movies i have.
So Options here , what can i get hardware wise that will allow multiple hard drives to be obtained and all be accessible at a good speed as using it for watching movies. Also hardware that allows hot swapping of a drive or all drives.
How it connects up is a choice of direct to router hardwired or direct to main pc as can always access main pc from other pc as remote access internal to lan will work fine. Media streaming/sharing.
So Please Options of how i can obtain this requirements. Willing to have a hot swap hard drive system in main pc as a start as room for one more external. I do not know what kind of hardware would be reqired for this and what hard drives it would accept.
I know there is usb hard drives but not sure of there speed for movie watching.
Please i need a lot of help on this one as i am at a complete loss of how this works. how ou can add a mass storage system to home network that has fast access time.
How you can add a hot swap hard drive system direct to external spare slot on pc under bluray drive.
Please supply options of this and with each option its speed and expandability of storage , hot swap capabilities.
I hope there are some members out there that have done something like this before even if its for a office but i am looking at a home version.
I look forward to reply's and accept any options available as i will be going ahead with plan as soon as i know what is required.
MY GOAL:-
Sata0 ,ssd
M.2 connector.
Chipset:
