This card is excellent, auto turbo to just over 1200Mhz, throttles down to 1150mhz when temps hit about 83C.
All heat is exhausted out the back (A lot of heat lol).
Chuffed with this build !
That seems poor to me
OcUk should get some EVGA Hybrid coolers in stock (available elsewhere), they'd fly off the shelves, perfect for every reference owner.
Maybe you'll keep it for longer than 5 minutes then
Glad you like it!
So after a short forray back onto the Red side I'm back on the Green Team...from tomorrow at least!
Decided to not half *** it and went for GTX 980ti![]()
Good choice, Nvidia have the edge atm AMD have that nice HBM and new small designs etc, but Maxwell is just so damn good that AMD can't keep up (Except at 4K). Not just raw performance but Maxwell's efficiency as well, and all those ROPS on top.
Reminds me of when Intel dropped the Core 2 lineup, Nvidia just have the egde and AMD don't quite have an answer... Yet.
HoF arrived: very quiet, nice temps, Asic 73.7.
Looks ace razor. I can fully understand why you kept the pre order. It was made to go in your case!
Do you find your reference card uncomfortably loud?
What was the asic rating on your msi g6 Boom? 66% here.You beat my Asic by 0.1%![]()
