confused, dual memory ?
20 Oct 2002
Oxfordshire / Bucks
just installed my msi z170a with skaylake cpu, corsair vengeance 2x4gb dual channel kit
installed everything, no output to monitor, so I took 1 stick of ram out and it worked
put 2nd stick in place of the other one to test it works, worked
put 2nd stick back in, nothing again
manual says to use DIMM slots 2 and 4, but that doesn't work, I tried slots 1 and 2 and that works ? is the correct of is the manual wrong?
try 1 and 3
should work in 3 and 4 for dual channel mode,right now your in single channel with it in slot 1 and 2
ive only just got it, so not updated bios, so no idea if its latest version or not
I have an msi z170A Gaming Pro
Corsair Vengeance LPX 24000C15 30000MHz
thanks for your help
More likely a typo in manual. If you have only 2 sticks then you should installed in slot 1 and 3 then when buy extra 2 sticks and these should installed in slot 2 and 4.
No - I've used MSI and Asus boards recently (past couple years) who want you to install in slots 2 and 4 first.
As for why, I remember reading that it's handier in instances where a cooler blocks the first slot. So makes sense.
Past 2 years? Try 15 years since DDR launched.
I been done installed memory sticks in ASUS, ECS, Gigabyte and MSI motherboards slot 1 and 3 over the last 15 years. Never had a cooler blocked the first slot, of course you can moved to slot 2 and 4 if cooler blocked slot 1.
on my msi motherboard it does say slots 2 and 4
I even asked msi directly and they also say slots 2 and 4
oh and your username, I had one of them cpus !!
I'll say it in a different way so you can understand - the primary dual channel on many motherboards, especially recent ones, now consists of slots 2 and 4 by default. And the secondary dual channel (for when you add more sticks) consists of 1 and 3.
Does the memory work in and 1 and 3 if you put it in them first anyway? Yes, in most cases. It's just not the primary dual channel.
So no typo involved.
