- 5 Aug 2003
- Essex
I had a similar sized slash in my tyre
http://i.imgur.com/pNclwLFl.jpg[IMG]
I just replaced. My thinking was for the sake of £160 or whatever it was, why risk it?[/QUOTE]
Took me a while to spot that... surely its fine? It doesn't look a lot deeper then the actual tread lines :confused:
You should get it changed because it's a **** tyre
If the internet didn't exist, I'm not sure I'd even be able to get dressed in the morning, let alone make a decision like that![]()
I have in the past ignored similar tyre damage to the OP, however having experienced a tyre blow out at ~70mph in the outside lane earlier this year and completely writing off my pants in the process - I would echo the above and get it changed.
http://tinypic.com/r/b8jngg/8
Another +1 for changing it. Rim protectors are there to protect the alloy from a scuff, not reinforce the tyre for added sidewall protection.
