- 7 Jan 2009
OpenElec on my AMD Htpc..runs beautiful.
Thanks for your reply Ferret. All im after really is to play my 20gig plus 1080p movies with HD audio and few 3d films. i HAVE AN htpc which cost quite a bit and my mrs laptop which both have windows on so i dont see the benefit from having another HTPC with windows on cause we won't be browsing or downloading on it. This is what im after Our HTPC and laptop download exc and then ill be getting a NAS for storage and then want something for our TV downstairs to show the Content And play everything without issues
Then openelec is the way to go.
It is less resource hungry, so you will get better performance, run cooler and use less electricity.
Fully supports all file formats I've thrown at it including 24bit HD audio and very large rips (hardware dependant, but generally better compatibility than windows).
Boots straight into Kodi.
Boots and wakes up faster.
Simple to configure.
Free
Just put it in a USB stick and try it...
What NUC do you use is it intel NUC im not after anything to flashy just something powerful enough for my MKV collection and does HD audio and play my music and also 24p. We have a WD LIVE TV that plays everything but don't like the interface and its sluggish
I think it is the 4rth gen i5. Was the first released with hd5000 graphics that fixed the 24p bug. It's complete overkill for kodi. I imagine there are cheaper ones that don't have the bug now.
) wrong though.Wasn't the bug only in Windows though?
Thought even the older ones were ok in Linux/Openelec.
Could be (probably) wrong though.
