- 6 Jan 2013
- Rollergirl
search maxwell tweaker and nvflash![]()
Could you link? I'm a bit paranoid about unknown sources.
How did you manage to modify your BIOS mate? I'm interested in this!
Immediately after I posted I changed my plans and decided a 1kW would be the better choiceI'd personally get a 1kW PSU with x99 and SLI 980Tis.
As for the GPUs, some have different components and different PCBs, I believe the MSI 6G is custom PCB as well as coming with their "military grade components", you'll have to do research on whether they're good or not, though![]()
Tomorrow (hopefully) I'll be purchasing a few parts for a tasty new build. 5930K or 5960X, Asus X99 Deluxe, and SLI 980 Tis.
I'm certainly going for reference cards. My question however, are there any hardware differences at all between the various reference 980Tis? Any use superior rated capacitors, VRMs, etc? The Zotac reference card looks to be a great deal, provided that it matches in terms of component quality to any other reference card and their warranty service is good.
I'm not too fussed about voltage restrictions as I can simply flash the BIOS of another reference card if need be.
Another quick question aimed at those with a Super Flower Leadex Platinum 850W or EVGA SuperNOVA P2 850W (same unit), how quiet are these under load? I've not found solid data for this unit exactly but the impression I get is that they are very quiet indeed.
Thanks all!
Gigabyte GeForce GTX 980 Ti Gaming G1 6GB Review
http://www.ocaholic.co.uk/modules/smartsection/item.php?itemid=1660
There's actually an evga hybrid currently in stock. Pretty sure thats the first time i've seen them listed as in stock and not a preorder.![]()
This monster arrived at home today:
I went for the Zoltac AMP Extreme mainly due to the high default OC, large cooler, and the 5 year warranty, plus I believe they have UK RMA.
It is unbelievably huge, and barely fit in my case. (Coolermaster CM 690 III) - I've only got about 5mm clearance at the end of the card.
Initially I thought it wasn't going to fit and I'd have to send it back, but here's a lip on the drive enclosure at the end of the case which the clearances trickier. A bit of jiggling around and the card fit - just, though I've since noticed the drive enclosure is removable so that would have made it easier to fit.
The good news is it's noticeably faster out of the box than the Gigabyte G1 it replaced - 16362 in 3D Mark Fire Strike vs 15621.
It also runs much cooler. The max temp I've seen under load is 72 degrees, while the G1 would go well over 80. It's pretty quiet too and less noticeable under load than the G1.
I did get a bit of coil whine in the Witcher 3 menus with Vsync off (when the game runs at over 3000fps!), but nowhere near as bad as the G1, and there's no coil whine at all in normal gaming, even at high frame rates. The G1 had audible coil whine in all games.
So from first impressions this one looks like a keeper!
.In regards to power this beast requires 3 8-pin inputs and when the button on the back is pressed the house lights dim.
