***The Vapers Lounge*** 2.0
Status
Not open for further replies.
why not an all day tank, you been using the coil heads or the rba?
I can see why with the coil heads, drinks juice way too fast, but the rba allows more sensible coils and with a 5ml capacity, its my main tank with my lemo 2 as backup/driving tank.
Chaps quick one,
I have an IStick 20w with an Aspire Nautilus Mini been good for a month but 1.8ohm I need to experience sub :cool:
Looking to get a SUBOX Mini Black Starter Kit from Fasteck for £34 with the exchange rate from Dollars.
Is this a good starter kit and is the website genuine? It seems there around £54 UK price so not a bad saving.
Would I need anything else or would you recommend anything else?
Chaps quick one,
I just did that exact move bar my mod was a 40w wismec. I vape 0mg and the difference in flavor is insane. I ordered from fasttech, took 2 weeks.
Fasttech is legit, just make sure what you buy is marked as authentic. Savings are good but with the trade off of potentially long delivery Windows. If you're not in a rush it's the way to go :)
Just ordered my self a youde goliath v2 :D
Fasttech is fine and as long as the items you order are marked as authentic, then they should be the real deal, but as others have said, it can take two weeks to arrive, though ive had an order arrive in 6 days and another took 4 weeks... the majority are around 2 weeks, just DO Not order batteries from them, this will lead to much longer wait times for delivery.
I got the TFV4 from Fasttech, but it's authentic, they do 2 versions, a tank only and a kit, the kit gets you the Tank, a spare glass tank, 1x 0.15ohm Quad coil head, 1x 0.2ohm Triple coil head and the RBA deck with and 0.85ohm single coil, plus two large vap bands.
I got the kit, think it was about £22.00, love it so much ive got a second on order.
I'm going to get the TFV4 from FT once they start selling the replacement triple coils.
I have not tried the triple coil head yet, only the quad and RBA, the quad takes at least 50w to get it working and I was happy with the vap it gave at that, but at 100w it really shines, though you need the Top and Bottom airflow fully open to cool the vap down to a more manageable level... I believe the triple will work with slightly less power, but if its close to the quad... prepare to go through juice like its out of fashion lol
If you order from Fasttech and don't order batteries, always pay the extra $3.50 odd for "e-packet" delivery, if the items are in stock, you'll get the delivery in a week or so.
Ive had two orders from FT now.
One free postage one "E-packet" the first order took 7 days the "E-Packet" order took 8, not convinced its actually worth paying the $2.50 for
I always select the Free China post that specifies 6-14 days, and typically get my order within the 14 days.
Just check the Shipping dates, usually under the price will be a note if something will ship in 5 days or 10 etc.. order these as separate items if you have a bulk order so you get the rest of the order posted straight away.
My Vamo V5 and Kafun Lite has finally died after one drop too many so just bought a Innokin Coolfire IV and isub G to try out some sub ohm vaping.
But have read somewhere that a much lower mg should be used , is this correct as all my juice is 24mg.
Yes Leemk, if your going to sub ohm, I would seriously suggest a much lower nic juice, you will get such a bigger hit of nic on a sub ohm device and could make yourself sick.
Looking at getting the Original VapeCige VTBox200. I don't need 200w but for £70 I may just get it.
https://www.fasttech.com/products/3032/10015744/3017300
I really like the look of that, I wonder what the build quality is like as thats a very low price for a DNA200 device
Edit: How are you getting it for £70 its £100, Also looks more like a clone of the mustang M2 than an "original"
Because the company that makes it told all the resellers that if they sold it below $150 they won't get any.
Try using the code "PRICECONTROL" if it's still working you will get it for $114. But double check at the check out.
i have been sub ohming on 24mg nic for about 3 months now.
I find i am only using half as much juice as I did before now.
Status
