96 people died at a football match with over 700 injured.
should be banned as well?
For goodness sake!!!!
Yes. I think they are reviewing the whole area of Air show safety now according to the BBC
For goodness sake!!!!![]()
Quite few changes were made after Hillsborough.
I hope the same for these air shows.
The former hawker display pilot I mentioned earlier in this thread said that display aircraft are never pushed to their limits and probably around 50-60% of their capabilities
read up - the last big airshow disaster was in 1952 - big changes were made then , and a safety record for bystanders of 62 years without incident (yes pilots have been killed but not those watching or passing by).
I can see the shoreham event either being cancelled or moving to the seafront;
the reason it was at the airport so they can charge for it!
I don't need to 'read up' to know this shouldn't have happened. I want measures put in place to ensure it doesn't happen again.
His point is valid, although his example is a little poor.
Are you suggesting we need a blanket ban on all airshows over land?
It's also worth noting that the pilot did not have authorization to do the maneuver, so no amount of rules/safeguards would have stopped this.
Doing a loop an any near 70 year old plane is always pushing it, either the pilot or the plane exceeded it's limits.
Doing a loop an any near 70 year old plane is always pushing it, either the pilot or the plane exceeded it's limits, granted it seems more likely the pilot however if it had been a Eurofighter/SU-35 the would have been no accident so the planes limitations were also a factor even if not the primary ones.
You're really going to go against the knowledge and experience of an ex hawker Hunter display pilot who knows very well the limits for such aircraft , ok lol
If this is true then any deviation from what is authorised should be dealt with harshly.
However, what evidence is there to suggest it is true? Could it be the organisers attempting to cover their tracks because the proverbial hit the fan?
