So there are only two options now then?
pretty much?
human error
mechanical error
third option
aliens.
this is the first time in 62 YEARS that bystander and none involved lives have been lost at a UK airshow. yes aircraft have crashed and yes pilots have died. but this is the first time since Farnborough in September 1952 , others have been killed.
Doing a loop an any near 70 year old plane is always pushing it.
when you have to narrow your statistic down so much that you exclude the majority of events you know your reaching.
The age of the plane or even the loop isn't the issue here, it's WHERE it was being performed that's the issue and should NEVER have been allowed!!
Had it been performed over empty fields or sea the only casualty would have been the pilot
for a start the aircraft is 50 not 70
the US airforce flies aircraft of a similar age on combat missions
as for not having an accident in a modern type - an SU-27 asw flown into the ground in paris and who can forget the F-16 crash at a thunderbirds display.
an accident is usually the end result of a series of unfortunate events. so for not authorising a half Cuban or quarter clover - only the display director will know that as the flight plan would have been passed for him to sign off. And he hasn't spoken about it.
quote me 1 event in the UK , where anyone other than the pilot has died in an accident?
pretty much?
human error
mechanical error
third option
aliens.
And where would the inland airshows be held?
Its an unfortunate and rare incident , I'm sure there's areas where risk can be reduced further but blanket banning overland display isn't the way forward
Which planes? (Not trying to argue, genuinely interested, I thought the A-10 was their oldest active combat aircraft).
The F-16 is a late 70's jet and the SU-27 an early 80's jet, the EF/SU-35BM I mentioned are much newer/better designs. But regardless I wasn't saying modern jets don't crash, just that a modern jet like the ones I mentioned wouldn't have had this crash.
Indeed, however the media are reporting it was unauthorised (but then you're right, no way to know for certain yet).
And for reference I have done many loops in aircraft much older than a Hunter and it was fine, other than them being crap and having to dive to get enough speed to actually do a loop I felt perfectly safe
Health related?
and again you've done exactly the same thing you're narrowing it down and excluding the majority of the events to the point your statistic is meaningless.
theres been 6 fatal instances at air shows this year alone.
it was an SU-30MKI with thrust vectoring which crashed in paris in 1999
Again I didn't say modern planes don't crash, just that the ones listed wouldn't have had this crash (an MKI being a good example of a plane that could have completed the Hawkers loop safely).
none of which were bystanders in the UK - which is exactly what I am on about
also most of those were not in the UK anyway.
which makes your widening of statistics to the point of meaningless
In areas where the stunts can be performed over empty fields/land instead of highly populated public areas
It's really not rocket science, just common sense and basic logic shirley
