- 30 Nov 2011
The +100 core hits 1467 on boost. I've also noticed that the card is more stable when running the heaven benchmark in full screen opposed to window mode. Not sure if this affects anything?
I'm not sure what you mean about the power limit flag? I have set the power limit to its maximum in MSI afterburner; I monitor the percentage in the hardware monitor.. thoughts?
Your looking at "GPU Power %", you need to look at "GPU Power Limit" which will be 0 when it's not being limited and 1 when it is, or "GPU Voltage Limit" again will be 0 or 1
