- 6 Jan 2013
- Rollergirl
I've been using Mayhems H2O with a silver kill coil for a couple of years and no hassles. OCUK don't have any H2O in stock, so would normal DI water and a kill coil suffice?
Just to clarify the question, is a silver kill coil as effective XT-1? I'm particularly interested as my CPU block will be copper based but my GPU block will be nickel.
Is that in place of a kill coil?
Using Car Plan De-Ionised Water 2.5ltr £1.10 from Asda with Mayhems XT-1 Contains- Synergistic corrosion inhibitors to protect metal/Contains scale and biological inhibitors to help prevent fouling.
Emptied my sons loop the other day containing the above and it was still clear after 14 months.
halfords do really good DI water for under £5
Car Plan is all I have ever used in my loop since I started watercooling along with a additive and I have never had any problems. I have even gone for more than 2.5 years without draining and nothing was gunked up.
