- 12 Feb 2009
- UK
I had a face palm moment when I got the desk because of this.
Figured out that you can ease off the plastic blocks on the clamps (see link for a pic of the blocks) to give more clearance. Just get a flat screwdriver and ease each side off, they are only clipped on.
I then cut a thin bit of wood to go under the desk to spread the load.
http://www.thebuzzmedia.com/wp-cont...g-force-gt-ps3-wheel-mounting-clasp-grips.jpg
How is the quality of that cupboard under the middle of the desk? Have you a photo of the inside?
I was going to use 2 of the draw versions on a desk im planning but the wife things we should have one of those.
