Hmm, I might try that.
Hurrah, it worked! Thanks!
Biggest climb: 1,124ft. That's more like it!
good stuff!!
Good work on the commencement of logging
I'd dump the protein shakes immediately. You don't need anywhere near 203 grams of protein so those 300 kcal could be put somewhere useful instead.
If you want to add me on MFP I'm "aekeron" on there. You can then share your food diary (or just make it public if you like). I will be able to comment on your portion sizes and the choices you've made for certain food types. Some of the kcal and macro data on MFP is a bit dodgy so sometimes you'll want to pick another option for one of your meals/foods/etc.
Id say getting to 3k+ kcals/day is not going to be super easy if he's not used to eating that much! I need around 4k and I struggle every day..!
you don't need that much protein sure, and if you've got better way of filling yourself up like lean meats etc then I'd do that! you're not trying to body-build.. all you're doing is trying to gain weight so you need a good quality food and go 300-400kcals over your maintenance!
