Permabanned
- 23 Apr 2014
- Hertfordshire
WHS 2011, Sabnzbd, Sonarr, Plex.
If you can get 2 that would be perfect for the amount of VMs you would need. I splurged a little on my host but I struggle to fill the SSD on it with lab machines tbh.
120gb should be ok if you have other drives to store less high access things like isos etc. It will be able to store quite a few VMs if you use differencing disks. I have a 2012r2 base vhdx which takes ~10gb in core mode which I then attach differencing disks to when I need to test stuff. This way you can spin around 6-7 VMs inside 120gb easy.
I currently just have an HP N36L Microserver with Xpenology and 4 x 3TB drives. This hosts all my files, Plex server, SickBeard, and SAB.
I'm considering either moving all of that to a proper Synology NAS and repurposing the N36L as an ESXi box for a lab or maybe just going out and buying a Gen8 Microserver for the lab.
