Gaming Rig. These specs good?
2 Dec 2004
Under The Desk, Wales
I am thinking of building an ITX system or buying a gaming laptop. Now, thing is, i am not too clever on ITX components. I have built many PC's over the years so know my way around a build but i need advice.
I have listed the components i quite like.
Now, will this setup all fit together, firstly as a good gaming machine, secondly, 'in that case' and thirdly as a quiet solution?
I know a GPU fans/s can be changed etc but any one can help with these questions then that would be great.
I already have an SSD, DVD Drive and Win OS. Ta
4GB AMD RADEON™ R9 380
or
Geforce GTX 960 2048MB
Not got a clue sorry so any help would be superb!
I've literally just built the exact same PC, in a different case, CPU and Mobo.
It would all fit, providing the GPU is short enough but i'm guessing you have already checked.
As far as a good gaming PC? It'll hold well at 1080p but you won't be maxing out the latest titles but then again you can't expect that. The 960 is an awesome little card for the money, i got the windforce ITX one and even though the fans are against the edge of the case the temps were good and it was silent!
I wouldn't bother with changing the cooler to be honest as you can't overclock and I can't even hear mine!
Ok, so i could use stock fan on CPU. Is that PSU quiet? GPU quiet?
I may get 1 stick of ram instead, 16gb futureproof i guess.
That system would play most games then? CPU more than capable?
Thanks for advice
Yeah i'd use the stock fan. I've never been able to hear any of the PSU's I've owned but the PC is absolutely silent, even in gaming!
I've got 8gb and won't see a PC like that needing more any time soon to be honest. Although DDR3 is getting really cheap now DDR4 is out.
Yeah CPU is fine. It will compliment the GPU nicely. I'm getting about 90% CPU usage in games on mine @ stock.
Easily, you won't be getting ultra on GTA 5 etc but any other game you'll be laughing :)
Have you gone for the 960 due to budget restraints?
I'd spend a bit extra and get the 970 if i were you and get double the vram.
That case will take the longest GPU's available.
Any reason why as i am a noob and know nothing! lol
The 'K' models have unlocked cores, so can be overclocked to give extra oomph to your rig.
Bear in mind overclocking will require, not only some knowledge but decent cooling and a decent psu as you are increasing the voltage and thus increasing temps.
Deffo worth the extra £30 mate.
Ok, looks like 'K' model then.
I like the Frac Core 500 case. I might look at getting a low CPU cooler with big fan.
I may go ahead and build this. The CPU and GPU will play all modern games? I am not fussy about ultra high settings in games.
Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - Retail
Gigabyte GeForce GTX 960 OC 4096MB GDDR5 PCI-Express Graphics Card
BeQuiet Pure Power L8 530W '80 Plus Bronze' Modular Power Supply - With 120mm
Silent Wing Fan
Asus H81I-Plus Intel H81 (Socket 1150) DDR3 Mini ITX Motherboard
Black Phanteks Enthoo Evolv ITX Mini-ITX Chassis with Window - Black
Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
Total : £559.04
I already have an SSD I will use and Win 8
This spec ok guys?
looks ok for your budget matey. :)
Looks like your 960 will fit in that case fine.
Remember you'll need an external optical drive for any cd/dvd/bd disks.
