Ashes of the Singularity Bench
Man of Honour
21 May 2012
Dalek flagship
Settings.
Please check that the settings have not changed once you have completed your run.
Simple Rules.
Any normal resolution can be used up to and including 4K.
Runs can be done in DX11 or DX12.
Single GPU runs only please, using multi GPUs can hinder your score.
Please post your GPU and CPU clocks.
Please post the resolution used.
Please post your result in the format as shown below in the spoiler.
Single TitanX @1127/1752
5960X @4.0
2160p
Thread Navigation Links.
Man of Honour
OP
21 May 2012
Dalek flagship
1 GPU 1080p DX12
  1. Average FR 48.8, GPU TitanX @1409/1652, Normal FR 57.1, Medium FR 48.8, Heavy FR 42.6, CPU 3930k @4.4, Gregster Link
  2. Average FR 47.3, GPU 980 Ti @1484/1974, Normal FR 58.7, Medium FR 46.2, Heavy FR 40.5, CPU 5820k @4.625, andybird123 Link
  3. Average FR 43.4, GPU Fury X @1120/560, Normal FR 49.3, Medium FR 42.1, Heavy FR 39.9, CPU 3770k @4.2, Dygaza Link
  4. Average FR 38.0, GPU Fury X @1050/500, Normal FR 47.2, Medium FR 37.9, Heavy FR 31.9, CPU 5930k @4.375, muziqaz Link
  5. Average FR 36.0, GPU TitanX @1400/1866, Normal FR 45.5, Medium FR 35.6, Heavy FR 30.0, CPU 5930k @4.3, Streetlight Link
  6. Average FR 33.6, GPU 290P @1285/1500, Normal FR 41.0, Medium FR 33.9, Heavy FR 28.3, CPU FX-9590 @5.0, Streetlight Link
  7. Average FR 33.2, GPU 290P @1190/1300, Normal FR 41.7, Medium FR 33.3, Heavy FR 27.6, CPU 4790k @4.7, thebennyboy Link
  8. Average FR 21.7, GPU 970 @1450/1900, Normal FR 27.2, Medium FR 20.8, Heavy FR 18.7, CPU FX-9590 @4.6, humbug Link
1 GPU 1080p DX11
  1. Average FR 39.0, GPU TitanX @1471/2002, Normal FR 53.6, Medium FR 39.2, Heavy FR 30.5, CPU 5960X @4.5, Kaapstad Link
  2. Average FR 22.6, GPU 970 @1450/1900, Normal FR 29.7, Medium FR 22.3, Heavy FR 18.4, CPU FX-9590 @4.6, humbug Link
Man of Honour
OP
21 May 2012
Dalek flagship
1 GPU 1440p DX12
  1. Average FR 40.5, GPU TitanX @1409/1652, Normal FR 46.9, Medium FR 41.4, Heavy FR 35.0, CPU 3930k @4.4, Gregster Link
  2. Average FR 38.8, GPU 980 Ti @1484/2000, Normal FR 45.7, Medium FR 39.5, Heavy FR 33.2, CPU 5820k @4.625, andybird123 Link
  3. Average FR 36.1, GPU TitanX @1400/1866, Normal FR 43.8, Medium FR 36.3, Heavy FR 30.6, CPU 5930k @4.4, Streetlight Link
  4. Average FR 27.8, GPU Fury P @1000/500, Normal FR 32.9, Medium FR 26.6, Heavy FR 25.1, CPU FX-8370 @4.7, Nutella33 Link
  5. Average FR 21.7, GPU 290P @1270/1500, Normal FR 27.8, Medium FR 21.7, Heavy FR 17.9, CPU FX-9590 @5.0, Streetlight Link
1 GPU 1440p DX11
  1. Average FR 41.9, GPU 980 Ti @1484/2000, Normal FR 51.9, Medium FR 41.9, Heavy FR 35.1, CPU 5820k @4.625, andybird123 Link
  2. Average FR 30.7, GPU TitanX @1430/2001, Normal FR 41.0, Medium FR 30.2, Heavy FR 24.9, CPU 3930k @4.625, Gregster Link
[*]Average FR , GPU @/, Normal FR , Medium FR , Heavy FR , CPU @,
Man of Honour
OP
21 May 2012
Dalek flagship
1 GPU 2160p DX12
  1. Average FR 20.8, GPU 980 Ti @1452/1842, Normal FR 25.5, Medium FR 19.9, Heavy FR 18.2, CPU 5930k @4.4, rickyjb Link
  2. Average FR 20.3, GPU TitanX @1127/1752, Normal FR 24.5, Medium FR 19.4, Heavy FR 18.0, CPU 5960X @4.0, Kaapstad Link
  3. Average FR 19.0, GPU Fury X @1050/500, Normal FR 23.4, Medium FR 18.1, Heavy FR 16.7, CPU 5820k @4.4, ALXAndy Link
  4. Average FR 18.6, GPU 290X @1200/1500, Normal FR 22.0, Medium FR 18.3, Heavy FR 16.4, CPU 4790k @4.7, bloodkil Link
1 GPU 2160p DX11
  1. Average FR 23.8, GPU TitanX @1491/2002, Normal FR 31.2, Medium FR 22.6, Heavy FR 20.1, CPU 5960X @4.0, Kaapstad Link
  2. Average FR 22.3, GPU 980 Ti @1452/1842, Normal FR 28.4, Medium FR 21.2, Heavy FR 19.2, CPU 5930k @4.4, rickyjb Link
30 Nov 2011
980ti 1480/8000
5820k @ 4.625
1080p
29 Aug 2010
Cornwall
Interesting that the option have a tick-box for FreeSync, I didn't think FreeSync needed explicit support from the game. Also, why no GSync option? Is this a Gaming Evolved game/Benchmark?
Does FreeSync make any difference to the scores?
5 Dec 2010
The Moon
To get the settings... Choose Crazy from Quality Profile........ then restart the game....
all boxes will be on high bar MSAA which will be on off...
Add MSAA x4.. then restart the game....
you should then open the video options to check that you have all the right settings.
changing them and not restarting the game will change the settings to a lower setting.
And CPU test off keepstad?
Tip for all and andybird(Ti pulling 11FPS more then my titan-x:eek:)
Caporegime
12 Jul 2007
United Kingdom
I was holding off starting a bench thread until the bench hit Beta as there is a bug whereby the right settings are not applied.
Happy for Kaap to do it though, it's in good hands.
