Data Recovery Issue - Folders showing, files notq
29 Jun 2005
Newcastle
My mother's laptop recently went the way of the Dodo and I said I'd try get her files off for her (mainly for family holiday photos etc).
I've bought a SATA to USB cable online and plugged it into my PC and it does seem to recognise it, showing up in My Computer. The strange thing is, when I open it up in My Computer, the folders will show.. I can browse all the way from "Users" to "Pictures", "Documents" etc, but as soon as I open the My Pictures folder it's showing as empty when I know it wasn't.
I've a feeling I'm missing something glaringly obvious but it's been a while since I did something like this. Any ideas?
Also worth adding that I've got "Show Hidden Folders" checked as well.
Don
21 Oct 2002
Parts Unknown
^Yes
Although I'd try the following too..
Install 'Treesize', you can use this to scan a drive and it'll tell you where the bulk of the files are, great for drilling down folders that you're not 100% sure of the structure.
17 Jul 2008
maybe someone moved documents / pictures folder?
search the drive for jpg files, see where they are..
might want to chkdsk it as well
OP
29 Jun 2005
Newcastle
Thanks for the responses!
I managed to find them but plugging them into an iMac and they showed up on there no problem at all. I'm guessing something to do with the filing system?
