Turn any electrical socket into an internet connection with TP-Link!
Comment on the YouTube video to be in with a chance of winning it!
TP-Link AV1200 Gigabit Passthrough Powerline Starter Kit (TL-PA8030P KIT) @ £79.99 inc VAT
Using your home’s existing electrical circuit, TP-LINK’s TL-PA8030P KIT AV1200 3-Port Gigabit Passthrough Powerline Starter Kit turns any electrical socket into an Internet connection. Simply plug into your wall socket and you are ready to enjoy HD streaming and gaming, no configuration required. You also won't lose a socket with its integrated pass through socket included! With speeds of up to 1200Mbps for smooth Ultra HD streaming, online gaming or faster downloads, TL-PA8030P KIT is a perfect home entertainment companion.
1200Mbps! Perfect for Bandwidth Demanding Activities
With its advanced HomePlug AV2 technology, TL-PA8030P KIT is introducing a powerline generation for even faster data transmission in the home network. TL-PA8030P KIT supports 2x2 MIMO* with beamforming, so users benefit from ultra-fast data transfer speeds of up to 1200Mbps. Perfect for bandwidth demanding activities like streaming Ultra HD video to multiple devices simultaneously, online gaming and large file transfers. *The Multiple Input Multiple Output functionality within HomePlug AV2 significantly improves data transfer rates especially during peak periods. It uses any two electrical wire lines within a 3 wire network to boost performance.
3 Gigabit Ports for Maximum Connectivity
With 3 gigabit Ethernet ports, TL-PA8030P KIT can simultaneously connect up to 3 wired-only devices. This makes the TL-PA8030P KIT the perfect home entertainment companion. Connect any 3 devices from smart TVs and games consoles to NAS boxes and computers to the Internet at the same time. Just plug the Ethernet cable into the powerline and away you go!
Extra Power Socket for Additional Devices
Where sockets are at a premium, the TL-PA8030P KIT with an integrated AC pass-through power socket, means the powerlines can be used like a traditional electrical socket. Plug your smart TV or games consoles into the powerlines, as if it were a normal plug socket. No socket needs to go to waste. The built-in noise filter helps to prevent electrical signal noise from affecting powerline performance.
Plug and play, no configuration required
TL-PA8030P KIT is easy to use as follow: 1. Plug a powerline adapter into a wall socket and connect it to the router, via an Ethernet cable. 2. Plug another powerline adapter into a wall socket in another room and connect it to your Internet enabled device via Ethernet - and you are done! The powerline adapters will automatically connect to extend your network. The “Pair” buttons on the powerline can also be utilized for securing or managing multiple powerline adapters in your home powerline network.
Reduce Power Consumption by Up to 85%
TL-PA8030P KIT, a new-generation of powerline adapter, with its practical design and sophisticated Power-Saving Mode, will automatically switch from its regular "Working" mode to "Power-Saving" mode reducing its energy consumption by up to 85%*. *Actual data will vary in different network conditions and environments.
Features:
HomePlug AV2 standard compliant, fully interoperable with HomePlug AV, ideal for using multiple HD/ Ultra HD devices simultaneously
High-speed data transfer rates of up to 1200 Mbps, supports all your online needs, with three years warranty
3 Gigabit ports provide secure wired networks for desktops, smart TVs and games consoles
Integrated power socket ensures no power outlet goes to waste
TP-LINK powerlines are compatible with all broadband routers and powerlines, plug and play, no configuration required
Warranty Information:
Manufacturer: tp-link
Warranty Type: Direct with Manufacturer
Manufacturer Website: http://uk.tp-link.com
Warranty Period (yrs): 3
Only £79.99 inc VAT.
ORDER NOW
Features:
ORDER NOW
