- 11 Mar 2013
I was convinced to buy the Swift and it was the best decision I've ever made on a monitor, stunning!
This^
My only annoyance is that now I have a very expensive monitor that ties me into only buying NVIDA graphics cards in future.
OK so just for clarification, when Freesync drop out of it's range, it will switch to standard vsync (so things like imput lag would be sure to follow)...but for Gsync when you say it will continue to work below the range, what does actually meant in terms of looking at the monitor when the frame rate is 25fps on a Gsync enable monitor vs conventional monitor without vsync enabled...does it offer any benefit in being smoother?
No it won't, read the review or watch the video and you'll see that G-Sync actually continues to work well below 30 FPS.G-Sync goes as low as 30 FPS, anything lower will be affected by tearing.
And secondly, oh my god is it a great TN
thing is, in most games, unless you are going to do a side by side comparison, you're probably not going to notice the difference.
