- 22 Feb 2014
We have a howdens kitchen with an integrated washing machine (so most likely a rebranded Beko)
Recently (last 4 months or so) washing of clothes has been hit or miss with regards to washing not smelling right.
Last night I disconnected the waste pipe from under the sink and ran it into a bucket.
The water that came out had kind of a dirty washing/smelly eggs smells to it.
despite the machine being run on an empty cycle.
The pipe itself didn't visually seem clogged and was pumping water into the bucket ok.
We have taken out the detergent drawer and cleaned that and the holes that pump water into the draw all seem clear (a little build up around them but not much)
We have tried to run a "machine clean" cycle which should take over 2 hours but finishes in 15 minutes with no error code.
Also checked the filter cover on the bottom of the machine which wasn't really clogged up (although we found a hair grip in there) the impellor was able to freely spin as well.
This indicates to me that there is a build up in the machine somewhere that is holding smelly water because after a couple of empty cycles the washing smells better but still not perfect.
I am happy to pull the machine out tonight and start to tear it apart when I finish work but it would be good to have an idea of what exactly I am looking for and where I should be poking before I start.
