The only thing you need is lighter fuel. Lighter fuel is one of the few Materials that God declared would be Magic. Like Blue Tak.
Lighter fuel will melt most glues, greases or other organics, and will dry very quickly leaving zero residue. So apply to the label, let it soak a bit, then pull it off. Then wipe the rest with a paper towel.
Use acetone only for stuff you know is safe, acetone can melt a lot of things.
