Cheers, could you suggest where I could get used 290X? Don't think I have access to MM. If not could you suggest a new card I could get instead?
Thanks
Heard of any online auction site? I can't post the name here since it's against the rules.
If you want new then you could get a r9 380 or gtx 960. Both should probably work with your existing psu.
Also look at this thread if you want to go for a 380:
http://forums.overclockers.co.uk/showthread.php?t=18690679
