Still not posted mine. I posted and told you my GPU clocks were bone stock and my 5820k was clocked to 4.4ghz yet you seem to have missed it.
Third time lucky and on the scoreboard.
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Scoreboard updated.![]()
Cheers, you've put it as a 290P btw, it's a 290X![]()
Well looking at those results I am still waiting to see Overclockers dream Fury X that will destroy everything in DX12.... As here i see 980ti as faster card :/
How can i force myself to buy FX over TI![]()
Being patient is the best option, Far too many unknowns for dx12 yet, Amd might pull a rabbit out of the hat with a driver boost, Or Nvidia might get more performance from async working.
Yes definitely something holding the Fury back. Look at the 2160P result. A 290X OC is only 1fps behind the FuryX. On Paper the Fiji core has 50 more SP's and a lot more bandwidth so theoretically should be a fair bit faster. Clock speed could be it but surely the extra bandwidth should have a benefit.
And as I mentioned earlier, anyone who are owners of benchmark threads I am participating are more than welcome to delete my entries, since they all are achieved with AMD VSR,
Lack of ROPs throttling it maybe?
Muziqaz would like all of his bench thread scores deleted![]()
Maybe a note should be put at the side of his scores since VSR will actually reduce fps a bit. This is interesting because his FuryX is overclocked a bit so should really be more than a couple of fps faster than the stock FuryX result.
According to AMDMatt, VSR gives slightly more fps over native resolution. I don't think it is right to have VSR scores but that's not up to me and down to the thread starter/updater.
If it is indeed VSR, Musiqaz's 4K result is only 0.6 fps faster so until we have more results it's difficult to determine if VSR is much faster or not. I was under the impression that VSR would take more processing power since the GPU would have to render at 4K then perform scaling to a lower resolution and add whatever postprocessing is needed to make it look good. On true 4K screens the 4K frame buffer is output straight the display.
