- 16 Nov 2011
So I have 2 Sky+ HD STBs, is there a way I can use both of them. So take the viewing card out of the main one and put it in the 2nd so I can use the disk space on both?
No because you have to "activate" or "pair" the card to the box. Without pairing you are limited to the channels you can receive, and would imagine even the sky+ features may be limited.
So can I pair it with two boxes, considering that both will be authorised through an internet connection and a phone line?
No because pairing with a box invalidates any previous pairings as far as I know
I already tried to put the sky viewing card in the other box, have a broken or de-authorised something now? It wasn't connected via a phone line though.
Shouldn't have done
Thanks. Also random question is there any way to disable pre-recorded on demand since with actual on-demand it is completely pointless.
And is there a max HDD size that you can put in the STB, so could I put in a 3TB or 4TB HDD?
Not as far as I know
On a 2TB box only 500GB is reserved for system use, you get 1.5TB personal space.
