** AMD R9 NANO NOW IN STOCK & AVAILABLE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
The worlds smallest most powerful graphics card, with a full 4096 stream processors and 4096-bit HBM interface this is one tiny card which packs a huge punch!!!
Asus Radeon R9 NANO 4096MB HBM PCI-Express Graphics Card (R9NANO-4G) @ £599.99 inc VAT
ASUS R9 Nano graphics card is powered by the brand-new Radeon™ R9 Nano graphics-processing unit (GPU). It's the world’s first small form factor (6-inch) graphics card with High-Bandwidth Memory (HBM) delivering new advances in power efficiency. Powerful performance for unbelievably “real” 4K and VR gaming. It's also bundled with a free 1-year premium license of customized ASUS GPU Tweak II and XSplit Gamecaster for intuitive performance tweaking and online streaming.
Features:
- Small form factor with a serious performance punch for mini-ITX-based PCs.
- GPU Tweak II with Xsplit Gamecaster provides intuitive performance tweaking and lets you stream your gameplay instantly.
- DirectX® 12 technology gets intense gaming performance and unrivalled image quality.
- 4GB 4096-bit high-bandwidth memory for higher bandwidth performance and less power consumption.
- Vulcan Support
- Mantle API
- DirectX 12
- Open GL 4.4
- Open CL 1.2
- AMD Virtual Super Resolution
- AMD Free-Sync Technology
- AMD XMDA Crossfire Technology
- AMD Liquid VR Support
- Frame Rate target control
- Dual BIOS
- HDMI 1.4a / 4k Video Support
Specification:-
- Stream Processors: 4096
- Core Speed: 1000MHz
- Memory Speed: 500Mhz (1000MHz Effective)
- Memory interface: 4096-Bit
- Memory capacity: 4096MB HBM
- PCI-Express X16 lane required
- 500W or greater PSU required
- Power Connectors: 1x 8-pin required
- Display Outputs: 1x HDMI, 3x DisplayPort
- Dimensions: 154*112*40mm
- Weight: 671g
- Warranty: 3yr
Only £599.99 inc VAT.
ORDER NOW
Gigabyte Radeon R9 NANO 4096MB HBM PCI-Express Graphics Card (GV-R9NANO-4GD-B) @ £575.99 inc VAT
Brand-new intuitive user interface helps you easily modify important settings and directly update driver and BIOS. Clock speeds, voltage, fan performance, and OSD setting can be monitored and tuned in real-time according to your own preference.
Achieve more than three times the bandwidth per watt over GDDR5 memory with smaller, faster, and more power-efficient High Bandwidth Memory on-chip, boosting gaming performance achieving high-framerates and smooth gameplay.
Supporting multiple independent display outputs simultaneously, AMD Eyefinity technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
Features:
- Vulcan Support
- Mantle API
- DirectX 12
- Open GL 4.4
- Open CL 1.2
- Dual BIOS
Specification:-
- Weight: 671g
- Warranty: 3yr
Only £575.99 inc VAT.
ORDER NOW
HIS Radeon R9 NANO 4096MB HBM PCI-Express Graphics Card @ £549.95 inc VAT
AMD R9 Nano graphics card is powered by the brand-new Radeon™ R9 Nano graphics-processing unit (GPU). It's the world’s first small form factor (6-inch) graphics card with High-Bandwidth Memory (HBM) delivering new advances in power efficiency. Powerful performance for unbelievably “real” 4K and VR gaming.
Features:
- Vulcan Support
- Mantle API
- DirectX 12
- Open GL 4.4
- Open CL 1.2
- Dual BIOS
Specification:-
- Weight: 671g
- Warranty: 2yr
Only £549.95 inc VAT.
ORDER NOW
MSI Radeon R9 NANO 4096MB HBM PCI-Express Graphics Card (R9 FURY X 4G) @ £575.99 inc VAT
Features:
- Vulcan Support
- Mantle API
- DirectX 12
- Open GL 4.4
- Open CL 1.2
- Dual BIOS
Specification:-
- Weight: 671g
- Warranty: 3yr
ORDER NOW
PowerColor Radeon R9 NANO 4096MB HBM PCI-Express Graphics Card @ £559.99 inc VAT
Features:
- Vulcan Support
- Mantle API
- DirectX 12
- Open GL 4.4
- Open CL 1.2
- Dual BIOS
Specification:-
- Weight: 671g
- Warranty: 2yr
Only £529.99 inc VAT.
ORDER NOW
Sapphire Radeon Fury X NANO 4096MB HBM PCI-Express Graphics Card (21249-00-40G) @ £559.99 inc VAT
The AMD Radeon™ R9 Nano graphics card is AMD’s most innovative and advanced GPU to date, delivering 4096-bit High-Bandwidth Memory (HBM), the highest memory bandwidth ever in a GPU, engineered for 4K and VR gaming – in a revolutionary small form factor graphics card – the ultimate GPU for Mini-ITX PC supremacy. Experience DirectX® 12 featuring async shaders and multi-threaded command buffer recording as well as support for OpenGL® 4.5 and Vulkan™ APIs. Push your gameplay to the max and achieve scorchingly-fast framerates at ultra settings by adding up to four GPUs with AMD CrossFire™ multi-GPU technology.
LiquidVR™ is an AMD initiative dedicated to making VR as comfortable and realistic as possible by creating and maintaining what’s known as “presence” — a state of immersive awareness where situations, objects, or characters within the virtual world seem “real.” Guided by close collaboration with key technology partners in the ecosystem, LiquidVR™ uses AMD’s GPU software and hardware sub-systems to tackle the common issues and pitfalls of achieving presence, such as reducing motion-to-photon latency to less than 10 milliseconds. This is a crucial step in addressing the common discomforts, such as motion sickness, that may occur when you turn your head in a virtual world and it takes even a few milliseconds too long for a new perspective to be shown.
Introducing HBM, a new type of memory chip with low power consumption, ultra-wide communication lanes and a revolutionary new stacked configuration. HBM’s vertical stacking and fast information transfer open the door for truly exciting performance in innovative form factors. And GPU applications are just the start – look for HBM’s superior power efficiency and space savings to spark industry-wide innovation.
DirectX® 12 is a new, “console-like” graphics API from Microsoft® that empowers game developers with more direct and obvious control of PC hardware. This direct or “explicit” control better exposes the hardware resources of AMD Radeon™ GPUs to yield higher hardware throughput and, ultimately, more performance for users. To put it simply: much more efficient hardware through smarter software! At the discretion of a game developer, this superior efficiency can be spent on higher framerates, lower latency (VR), lower power consumption, better image quality, or some calculated balance of all four. In any scenario, gamers stand to benefit greatly from choosing AMD hardware to run their favorite DirectX® 12 game.
We are taking you beyond the boundaries of traditional PC displays. AMD Eyefinity technology expands the traditional limits of desktop computing by multiplying your screen area. With multiple monitors, games become more immersive, workstations become more useful and you become more productive (an average of 42% more productive according to one study).
Take your PC games to the next level of reality and immersion. Most modern games look great on three screens, and only AMD Radeon™ graphics offer you the ability to play across five screens for an eye-popping gaming experience. Other combinations and configurations with up to six screens work too.1 Create your dream display.
AMD CrossFire™ technology is the ultimate multi-GPU performance gaming platform. Unlocking game-dominating power, AMD CrossFire™ harnesses the power of two or more discrete graphics cards working in parallel to dramatically improve gaming performance.1 AMD CrossFire™ technology ready graphics cards fit practically every budget. With the flexibility to combine two, three or four GPUs, AMD CrossFire™ technology is the perfect solution for those who demand extreme performance.
Watch the hottest Blu-ray movies or other HD content at full 1080p (and beyond !) display resolution. Enjoy a feature rich video experience with enhanced Unified Video Decoder 3 (UVD 3), offloading the bulk of the video decoding tasks from the CPU to the GPU allowing for a cooler, quieter and more balanced system.
The expectations of gamers have never been higher. Graphics quality and processing speed have advanced rapidly, and the games of today are light years ahead of those from just a few years ago. But advancements in game audio have been more sporadic and less widely adopted.
Sound is a critically important part of the immersive experience for gamers and sound engineers are eager to advance their art, but they haven’t enjoyed the same kind of attention that continually drives graphics improvements. Until now.
By leveraging AMD TrueAudio technology, game developers now have the ability to recreate acoustic environments with incredible fidelity, and to bring them to every gamer. With AMD technology inside all the most popular “next-generation” gaming platforms, including the PC, gamers across the entire industry will finally enjoy the best audio today’s technology can offer.
Real time control of maximum rendered frames displayed per second. DFC is aimed at providing smoother gameplay by limiting the maximum displayed frames per second for games whose frame latency vary too much, for example, if a game is keeping frame rate between 50 and 80 FPS, you can set a limit of 45 FPS and enjoy a smoother experience thanks to more stable frame latency. Even if the game is capable to deliver 60 FPS, DFC set to 60 FPS as target can also help by smoothing the frame latency .
Features:
- Vulcan Support
- Mantle API
- DirectX 12
- Open GL 4.4
- Open CL 1.2
- Dual BIOS
Specification:-
- Weight: 671g
- Warranty: 2yr
ORDER NOW
Just to check...is the current price include usually "OcUK instock premium", or is it really the RRP of these things? :eek:
Regardless...booo AMD for thinking with their bottom for the pricing of the Nanos lol
