Road Cycling
Status
Not open for further replies.
That's not new, they had those back in the nineties. Horrible devices.
yeah but the one's from 90's look stone age haha! :) I did try one moons ago on an mtb but I had nothing to compare with so I it's hard to judge without trying! the above looks very clean/minimalistic etc! i'd love to give it a go before buying tho :o
Dura Ace 9000, sram red xg1090 cassette ready to go on. Gonna see how my 23mm tires mount up, might have to get some 25's.
I have 25mm Michelin Pro 4 SC tyres on my H Plus Son Archetype rims. They come up pretty massive on there. Good ride quality as a result.
Going to see how much clearance I have, my 23's on ksyriums (GP4000S2) are about 5mm away from the cutout on my seat tube.
Some excess watercooling hose, 2 cable ties.
Bingo
Fizik do make one that fits in the logo cutout as well but i already had these lights when i got the new saddle.
Just got meself some Aksium Elites for £100, couldn't be happier :D
Saw your email buddy, good choice and a very well rated wheelset!
640mm average here, just we typically get a load or none at all. Not the constant drizzle and grey of England!
Haha was only kidding, I know some of you get plenty of rain! Any experience with Knog lights?
knog blinder? which one? they're SUPER good when it comes to actually working as a light, the usb connector is not a problem either, simply because the rubber snaps before anything happens to that ;) longest I had one last was like, 3-4 months? before it snapped, got a replacement and that snapped too while on the ride - no idea where it went :| got another one after that and snapped in less than a month... :(:o
Blinder 1 rear. I'll probably leave it attached (and only remove when it needs charging) if the rubber strap is that poor, I've never been a fan of them anyway on other lights long term.
Originally Posted by rossk26 View Post
http://www.ebay.co.uk/itm/2015-New-M...item2357a3c206
Anyone experienced buying shnidey jerseys from eBay. Heard some mixed reviews so far
Why would anyone want to wear Movistar?! ;)
I'd wear purple lycra now man, don't knock it
Movistar still do :D
My Cateye HL-EL340G arrived. I'd missed to notice it wasn't USB charging (comes with a normal power adapter) and it's quite big... Feels solidly made but I'm not 100% convinced it's fully waterproof as the plastic fitting battery shroud has no rubber strips around it... Also takes 8 hours to fully charge, could be easily solved with some extra batteries (they're just AA Ni-MH 2.2Ah) and an external charger. First Cateye I've been slightly disappointed with, but will reserve final judgement until I've used it in the dark! :D
I bought my bibs and jerseys from DHGate in china, so no doubt as genuine as those. They're fine for the money but a mate at work who rides a ton, says that you start feeling the difference between the crap stuff and genuine expensive stuff when it comes to 2hr plus rides.
Yeah - the pad is usually utterly guff on dodgy imports like these. I wouldn't recommend the bib shorts unless they're just being used for short commutes.
Status
