Cheers,
All I did was boot Win10 from USB, the installer found the drive and it installed OK. It's def the boot drive.
And you've definitely got the three partitions on your boot drive?
(IE. recovery partition, EFI system partition and the primary partition).
There is a fourth partition, but you can't see this with Windows disc management... need to use the command line to see it. This is the Microsoft reserved partition. I'm assuming here that the Windows installer installed in EFI mode.
Running latest BIOS (obvious comment I know)?
What does ATTO benchmark look like (screen print if possible)?
If you look at (but don't run ) AS SSD. Does the stuff in the info box look OK?
(two items should be in green with a tick). These are the controller and the offset/alignment.
I'll assume you know the basics (EG. only have the drive you are installing to connected when installing Windows etc. etc.) and wont insult your intelligence with basic stuff.
Unluckily, as far as I know... there is nothing yet out there that can read the SMART data. So that's no help.
PS. Never hurts after a new OS install, to check that all Windows files are intact (IE. run the System File Checker). Paranoid I am. Good job to. As initially I had certain windows (especially the Windows Settings) close on me of their own free will. Ran SFC /scannow from elevated command prompt and it found a couple of borked files and corrected them. Probably not your case, but worth a try.
