Man of Honour
- 16 May 2005
- Manchester
Wait..what? You just bought a bike that was the wrong size for you? Why?
I replied to your other post - get the 520.
Regarding locks...I'd actually personally get the following instead:
http://www.wiggle.co.uk/kryptonite-evolution-mini-5-flexframe-u-bracket-lock/
http://www.tredz.co.uk/.M-Part-Allen-Key-Security-Skewers_45216.htm?sku=117180
Just lock the mini-D through your frame and don't worry about cables for your wheels. It's not perfect, but it's pretty secure - more so than a bigger silver secure D lock and a cable for the front wheel.
I'd say get a mini one but make sure it comes with a cable too, if you lock it properly you shouldn't have to worry about skewers.
The good thing about the Triban is that you can go to your local decathlon and try it out. Even a 57 might be too big for you.
I'm 6ft and most of my bikes are 56cm.
Thanks man, but i'll stick to the amazon ones, the reviews are 95% positive, and friends recommended. Reply to the other post haha, just wondering what sora and microshift difference actually is..thats worth the £150 more spend
The entire point of using skewers is so that you don't have to carry around an annoying and easily cut cable.
Just cancelled my amazon one..will order your suggestion..too paranoid with cables now tbh..
You've made the right choice
Unfortunately no bike security is going to be perfect and it's all a case of balancing hassle for you vs hassle for the thief. A silver secure D lock is a fairly major deterrent and hence insurance companies being happy to cover expensive bikes as long as you can prove you've bought one.
If you lock up in the same place all the time it's possibly still worth getting a gold secure lock and just leaving it there (get security skewers too though). It's not like the gold secure lock is going to get stolen.
So, with the skewers, I wont need any cables at all, just skewer them into the wheel, and the frame with the D lock, and bingo?
Bought both of them, But i wont be locking up in the same place, I mainly cycle everywhere and anywhere just to beat times/distance. Like as a hobby you could say, I enjoy being free on a road, wont be to commute to uni or work though
Gold secure standard means squat. Look at how many gold standard chains got cropped on the Almax site in under 30s
don't buy rubbish chains.
FYP. d-locks aren't exactly unpenetrable.
personally id say if you want to leave your bike unattended for any sort of period, buy a comuter that you aren't that bothered about losing.
bike theves WILL take your bike if they want it. these guys roll around in vans with pretty much everything they need for a drive-by theft.
