*** The Official Destiny Thread (now includes 2.0 and TTK) ***
Same here, was yours coming via Royal Mail? If so have you checked your tracking number? Mine is not reconcongised by RM trace and trace.
What a joke. Last time I pre-order a game on Amazon.
Yeah, doesn't work. Talking too someone from Amazon support now. There telling me too called RM, I've told them the code doesn't work but they don't seem to understand :/.
There offering a free placement too be shipped, going too try for a fund.
Edit: Got the refund, its just processing I would do the same thing and then just go with the PSN store.
I think it's just been shoved in 1st class post, will likely turn up tomorrow. Absolute joke though.
Too late anyway now, but I didn't realise that TTK disc is just Destiny. I wouldn't have bothered with it if I knew that.
Wow the heroic strikes are hard as nails, but the rewards are insane. Taniks dropped two legendary engrams. Took fooorrrever though. Really good to play with a proper challenge. Had to run the taniks fight like skolas rotating around the arena always keeping someone on the run to get revives in.
First Year 2 exotic received from a purple engram dropped on a strike. The quest begins...
EDIT: Can't work out how to do this infusion thing. It seems to need another exotic piece that is higher than level 40. Is that even possible?
I was under the impression you did it to bring low level weapons up into line, not so you can further increase high level weapons?
It seems to want to consume a higher level piece but why would you not just use the higher item?
I tried buying the blueprint of the same item from the vault list but it wouldn't accept that either.
Because it's designed to allow you to level up favourite weapons instead of being forced to swap them for something else.
