Caporegime
Whoops, 10 down the drain already then (2 x 5) and nowt from them.
most people are spending marks elsewhere.
Very few have ploughed their first 125 marks straight into an exotic, considering how hard the new marks are to earn.
I know they can infuse old exotics but would have taken ages.
Question about exotic weapons. I've seen loads of people on Xbox running around with 280 Hawkmoons etc, I thought only a few weapons for year 2 upgrades?
Also PS guys, where does Hawkmoons drop, anywhere?
I'd be very tempted to start again. They've reworked how the story is done by using quests, so starting again would let you see how they've reworked it. Destiny has changed so much since the start it'll be like a new game anyway.Really tempted to nip out and buy the legendary edition.
I played destiny at launch and hit the soft cap, finished the "story" but then stopped. So never played the other addons either.
If i buy this version what will happen when i turn it on? Will it point me towards the last few expansions etc and i work through from there?
Or would i be best off restarting all together?
Are you intentionally dying that many times!?
Ok dumb questions incoming
1. Amidoingitrite?? As in everytime I get a new weapon, armour etc, the one I'm using I dismantle right?? As I'm trying to increase my light level. Or should I hang onto those lower damage/light armour and weapons??
3. Do I have to complete all the quests?? And when I do then are more going to appear?? I know in the last 2 DLC's once u finished off the storylines, you then went to get daily bounties etc etc.
As I said dumb questions that have me a tad confused.[/QUOTE]4. What is this 3 of coins?? I bought one which has got 5 of them. How do I use and when?? I ended up buying young ahamkara's spine from Xur.
2. Glimmer no longer drops when u kill a yellow boss in a quest or just patrolling around?? Also having killed the zealot that spawns, are u not meant get something good from it??
Wear your highest light item, if you get a great legendary but with low light, keep it. You can infuse higher light items to increase a lower light item.
I would, its a lot of fun, and when I was done I was Light lv220. After your done you get a tonne of side quests, I would do them all, some give you some good items, and legendary marks. I'm still doing the side quests and I'm light 245~.
I thought it did? I’m sure I have seen it dropping killing yellow bars. I don’t know if it is every time you defeat a zealot but get a passage coin for the Court of Oryx. There appears to be different ones for the different levels. I don’t yet know much about the Court of Oryx so can’t comment further on it.
