Yes.
Could never go back to gaming without G-SYNC (Or other such technology).
With it is buttery smooth. Without it, even at 100FPS, the game feels like a stuttery horrible mess.
Even with v-sync?
Yes.
Even with v-sync?
Yes.
Hmm. Is everybody in this thread happy to be forever on team green? Were you before? I mean, are you now less likely to buy an AMD gpu or wouldn't you buy AMD products before? No need to give reasons, just curious about whether buying GSync monitor has made you nV fans, or if you were nV fans anyhow, and GSync is just the obvious choice.
Any type of adaptive sync is awesome, I've tried both AMD's and Nvidia's, To me there was no difference but if you have the money buy an adaptive sync display, It's a treat for the eyes![]()
That sounds pretty great. Does g-sync add any latency like v-sync+triple buffering? Hate having to turn off those in most fps games and have tearing all over my screen.
Nope.
I hope we don't go forwards with two competing standards like this. VHS/Betamax all over again.
I'd love a g/free sync monitor, but I'm not going to lock myself in to one brand of gfx card. It's madness.
Compared to V-sync off, g/free sync does add a smaller amount of lag. Heck, it's even in AMD's/nV's presentations.
The only thing is the premium for Freesync/Adaptive v-sync monitors doesn't seem to be big,and there is far more chance that Nvidia will support Adapative v-sync at some point since AMD does and Intel will do and not the other way round.
An example is this monitor which comes in two versions:
https://www.overclockers.co.uk/showproduct.php?prodid=MO-030-AO
https://www.overclockers.co.uk/showproduct.php?prodid=MO-022-AO
They are basically the same monitor apart from a colour difference and the different scalers.
Edit!!
Here is the base model:
https://www.overclockers.co.uk/showproduct.php?prodid=MO-024-AO
There is a £20 premium for a scaler which supports adaptive v-sync and a £120 premium for a scaler which supports G-Sync.
However,the adapative v-sync and G-Sync versions do appear to have a better stand too,were you can swivel the display vertically so are slightly more expensive.
