What mic ? I'm in the process of sorting my drums mic wise...
I want simple
Thinking sm57 on snare another on Tom and two overheads
http://www.soundonsound.com/sos/feb14/articles/rode-m5.htm
And Shure Beta 52a on the bass drum
Simplish setup for drums that works pretty well:
Audix D6 on kick.
SM57 x2 on snare (top and bottom)
MD 421 x3 on toms (though 57's can be used if money's starting to get tight)
Sontronics STC-10's x3 for cymbals and hats.
That gives you a pretty good 'close' mic sound. But, it lacks depth - as pretty much any close mic recording does with drums. Ideally you need a room mic as well. There's a great technique that Clint Murphy shared not that long ago that requires a pair of AKG 414's (or similar condensers) that have an omni pattern. You place them a couple of meters or so away from the kit as a spaced pair, but have them pointing at the floor and the ceiling rather than the kit. Ideally you'll have a nice wooden floor and high ceiling for this. You then take the recording of the kit, stick it through an 1176 and smash the living whatsits out of it - super high ratio. Add a little bit of low end EQ, and then blend that fairly quietly underneath your close mics. The result is a much more natural sounding kit, that's also grown a pair.
There's a video showing my recreation of it here:
http://www.recordproduction.com/rec...ding-wolverhampton-university-andrew-lowe.htm
We don't have a wooden room, so we put plexiglass underneath the mics to help the sound bounce around a little bit. The audio on the video is purely the 414's, not the sound mixed together, so yes it's a little bit on the boomy side. The idea was to show how you can be inventive to get around having a less than ideal room rather than the final result in this case. Some other guys recreated it and took the door of the frame and put that under the mics!
