OcUK Cinebench R15 benchmark thread
I will update results table again shortly (as I seem to have drawn the short straw). They are currently up to post #598.
Again, one result per member per cpu. Multiple results on one cpu will take the highest one only.
If I cannot read the result or the CPU-z and cannot determine type and Hz, you may find yourself missing from the results.
glad to hear the table will be updated at last. here is a higher score with my QX9650 got past 5ghz now :cool:
Is this still updated?
FX-9590 @ 4.81Ghz, 1.48v / 1.46 V-Droop (Turbo off) 24/7 clocks.
756
First run with stock 5820k.
First chance ive been able to have a bit of an extended mess about with this system, (work hours and a borked hdd didnt help). Max temp of 54c, though for some reason cpuz errors on opening and doesnt show full chip informatuion?
Cheers Ian, should have a better run on my next delivery if Pete remembers! Made big improvements to mem efficiency and can clock a bit higher now I'm getting to know the board. Although I want to get testing VGA on cold again as I've not had much luck in that department yet, something always goes wrong!
What's the batch on your chip, I'm looking out for a better one!
12179696_1154138417948327_1501926482_n_zpsw42mv8be.jpg~original
Just built a rig for a friend of a friend.
X99 SOC Champion
i7 5820K
16GB Kingston Fury 2400Mhz
Zotac 980ti
Samsung SSD.
Overclocked core to 4.4GHz and Uncore to 4.0GHz nice and safe I feel.
12188340_10205156373164736_1566923092_n_zpsxcpydbuh.jpg~original
