I've rolled the dice on a Q666C![]()
Me too and a replacement tilt/pan head instead of the ball one.
When I see things like "taller and lighter" I get worried about stability. Although there are lots of variables (material, design, construction) invariably heavier tripods are more stable, shorter tripods are more stable, and taller tripods need more weight to as stable as a shorter similar designed/constructed tripod.
Make sure wherever you buy it from has a good return policy so you can try it out and return if not satisfied.
Amazon, and supplied by Amazon![]()
The Velbon has the option to hang a bag from it to improve stability if needed.- Looking forward to trying them out. Will compare to my Manfrotto 170
Should be safe with amazon.
You need the centre column to be there for when folding back. Else the head would get in the way of the legs.
That is a shame.
Mine has arrived and i have to say very impressed with it. Build quality is top notch, design is excellent, better features that the Q-666c variants (imo) and the ball head looks very serviceable.Sh4rkie said:I've ordered a DiC&MiC E302C from China for £78. It's another variation of the Q-666C theme but it's meant to be built with some improved features and gets some good reviews.
True test will be tonight with a 70/200 2.8 on it![]()
Honestly, phenomenal.How'd you get on?
What features does it improve on over the 666c?
Pleased as punch for £77!
