been dry. Won £25 last week and first win in about 6 months. Had 5 numbers once in first year of lottery. Thats was £5,500. You get nothing like that now for 5 numbers.
Ooooh what would you all do with it if you won?
I'd buy a racehorse.
i train to be a racecourse Vet and buy a shotgun
I know where to come for an insurance job then?![]()
I haven't done it since it went to £2, prior to that I did one LD per draw. If I fancy it I just do the euro. There was no need to change it from a quid.
i could have it sealing envelopes in no time![]()
We are in troublethey deleted all our messages from the swearing thread.
I only just got hereand I was having such fun!
freefaller was just jealous of our blossoming romance![]()
Oh dear. All mine are under 24The trick witht he lottery is to select all your numbers above 31.
That means when you do win 4 or 5 numbers you payouts are much higher.
Reason been that so many people put their birthdays on on statistically there are more numbers 1 to 12 (months) selected and then 1 to 31 (days).
The only statistic Camelot ever released in the early popular days was that if 1,2,3,4,5,6 ever came up then there would be approx 10,000 people sharing the jackpot.
You would be gutted if that was you. You think you have won a share opf £20m and find out you get £2,000 lmao
easy to check, check the results where all the numbers have been low and see how low 4 and 5 numbers and even 5 plus bonus are compared to weeks when all the numbers ahve been high.
You get at least double the payout![]()
How many of you have won something in the last 2-3 years doing it? If so how much
Also
Has anyone won anything in the last 6 months, how much?
Not counting the odd £10 or £40 low ones
Yes, it makes it easier for the fixers to rig it.
