- 10 Jan 2009
- Now live in Scotland !
I've got my heart set on the Thermaltake Riing 12 Red LED 120mm fans (8 of them) all to be controlled by a fan controller (AquaComputer Aquaero 6 XT) , i know this will be controlled by volts and not PWM as the fans are not PWM.
as these fans are 3 pin and and the headers on the 6 XT have only 4pin fan headers how would i be able to hook these up and have them on auto heat adjust along with the EK-Dual DDC 3.2 PWM X-TOP . or is it all controlled by the heat flow of the pump ? also heard that this pump is noisy on full .
im a noob at this watercooling lark and ive nearly got all my parts apart from the riing 12 fans as i didnt want to purchase them in case i cant get them to auto adjust to temps from either the CPU header or the pump .
on this article it seems it can be done but does not mention on how to hook up the 3pin to a 4pin PWM .
http://thermalbench.com/2015/05/22/thermaltake-riing-12-led-120mm-fan/3/
my whole build is based on these fans to be a certain color.
or am i better of getting the RGB versions of the same fans that are PWM but to change the colors of the fans they need to be plugged into the controller that comes with the fans themselves and would this be difficult to put into the XT 6 ?
sorry for sounding out to be a noob on all this just to cool 2 x 480 rads .
the whole reason to watercool is for a near silent pc while just surfing and moderate while gaming as the pc will be in same room where my partner and baby sleep .
thanks
thanks
,u have 4 fan connections so probably two with splitters attached for your fans,and the other two with the pumps
