- 14 Nov 2006
- UK
So I had vanilla destiny with the two expansions although never played past level ten.
I've recently just gotten TTK and have a couple of questions.
Where do I get the year 1 VIP rewards? Do I need to be a certain level for the quest to pop?
If I use the level 25 boost its it still possible to revisit the old quests? Is it recommended I play through the first 25 normally before boosting or should I just boost and get going as I won't miss much?
I had the frontier shell on my old character but if I create a new one I don't receive it from the post master? Is this only designed to be given to one if your characters?
I think you only got the Year 1 rewards if you had a character at level 30+, could be mistaken though.
Yes, you will be able to play all the missions and quests. The spark of light just gives you instant 25 plus a set of gear so you can go into the taken king stuff right away if you wanted.
It used to be at the special orders lady in the tower, but she's been removed now. There was a kiosk to replace her but I can't find that now since taken king.
not done the new raid yet, will it be do-able with a group from lfg? I have two quest lines that both need me to do kings fall so need to start trying to get a group together. 294 light now.
It will be doable, but probably better using the raid group thread on here.
