*** The New Cases Gallery ***
Damn. That is nothing but pretty.
On a sensible note... How are the temperatures?
Well, I haven't really done any testing as such yet, everything is pretty much at stock.
The CPU & GPU are both about 32oc at idle, which I know doesn't mean a lot.
The Strix never went above 67oc with a 50% fan curve applied, that was on MGS V @ 2560 x 1600, all options maxed out, but is was capped at 60hz on Vsync.
As for the CPU, its at stock, so haven't really seen it above 40oc under load in a game.
But as I say, need to do some more testing, and overclock that CPU a bit....
The top is 6mm toughened glass with a slight tint on it.
I never bought it to actually use as a desk, only because I use an Obutto R3volution cockpit for gaming purposes.
I purchased it, with the sole intention of only using it as a pc case, and a nice display piece, but also
somewhere where I can place some minimalist items on it, like docking \ charging stations etc.
Put my X99 setup together the other evening.
Will probably remove the red fan rings and replace them with ones painted yellow. Power cables will be replaced with black and yellow braided custom extensions. But ill be stuck with the red on the gpu. An msi lightning 980ti would be perfect but I cant be bothered with shifting on my current gaming edition.
Specs are.
Msi mpower X99
I7 5820k
16gb gskill ripjaw 4 3000mhz c15
Msi gaming edition gtx 980ti
Samsung 840 ssd
Samsung F3 1TB
Superflower leadex 1000w platinum
Enthoo primo
Fair enough, it looks awesome either way, so good job on that :)
That looks awesome, Setter - Couldn't you remove the cooler of the 6G and paint it yourself? You'd risk losing warranty though I'd imagine.
Is that the Primo Full case?
Thanks Joe, I could remove the cooler and paint it but warranty would be a big concern. Case is indeed the primo full tower.
Looks good Mr Setter ;)
The Enthoo Primo is indeed a very nice case, I used to have the same case in white before I got the Lian Li desk.
Fantastic cooling, great fan control, but it does weigh some, doesn't it :D
I am still waiting for OcUK to stock those white magnetic LED's, but here is my, otherwise, system.
It may not look as 'PRO' compared to other's builds, but
I am very proud of it :)
