Watching SP4 ad video.
* Fingerprint reader is available in the US only. Why?
In the presentation it was all a bit odd, he said finger print reader was basically for sp3 users, as sp4 uses facial recognition.
MobileFun.co.uk
Lumia 950 £450,
Lumia 950 XL £550.
I want 950xl for £400 wonder what the price wild be in Jan, generally they don't hold there rrp long.
So, just to be clear - I can buy a surface pro.... then later on get the additional power of the surface book, by buying the aluminium case in which it sits?
20MP auto focus with two-stage capture key
Digital zoom: 2x
6-lens optics
Optical image stabilization
Sensor size: 1/2.4"
F-number/aperture: f/1.9
Focal length: 26mm
Flash type: Natural flash
Features: Backside-illuminated image sensor, High-resolution zoom 2x, PureView, True 16:9 sensor, Fast Focus
Minimum focus range: 10cm
No, two different devices
Windows 10 should solve this. The converting functions from iOS or Android with minimal effort from developers is going to help.
Support - They can't just release the app and watch the money roll in. They have to add features, fix bugs, and listen to user feedback. If you're a small developer with limited resources, keeping up with two apps (iOS and Android) is enough of a challenge. A third ecosystem adds to
Complexity added by Astoria - Fixing bugs on code that's made for a platform is one thing. It's another to have to fix a bug that's going through a code convertor. Now you have to determine if the issue is with the original code or with Astoria.
Astoria apps won't be universal apps - Unlike Islandwood for iOS, Astoria apps will only run on the phone. My guess is there'll be far less interest in Astoria than Islandwood for this reason.
Low payout - If there's very low returns in the Windows Phone store, there's little reason for devs to create or even port apps to the platform. Obviously, it's too early for us to know if this is the case.
Lack of interest/awareness - Realistically, this is the biggest hurdle to me. Devs have to both be aware of Astoria and interested in the Windows Phone platform.
Devils advocate: why would they? Developers are lazy, and this is a very fashion conscious industry. Why would you want to go through the awful experience that is the windows store just so your app can be run on an OS nobody really uses anyway? If it ran on proper Windows, maybe, but WP?
At the end of it, you'll end up with an app that probably will have compat issues, so you'll end up wasting time on it, creating forks in your code or a new abstraction layer.
Why would anyone bother with all that now? The sane approach would be to wait and see if wp10 gains traction, which is exactly the situation we were in with wp7.
Hope that we dont have to wait long for UK Surface prices/dates.
