- 6 Sep 2005
Hi everyone
I'm having some real problems with my graphics cards, they are:
Sapphire R9-290X 8GB in crossfire, from OCUK of course.
The problem seems to be:
Heat
I know it's an issue with AMD cards, GPU 1 frequently goes up to 85C and the fan sounds like a jet engine, this happens very quickly after games start up.
I am aware of how menus can stress GPUs so I am talking about when it is in game and V-SYNC'ed to 60fps.
I am going to move and clean the PC out tonight to give it the absolute best chance of cooling possible and see if that makes a difference. The cards are in an Antec 1200 case so there is plenty of airflow.
Crossfire doesn't seem to work
Crossfire doesn't seem to work at all! I can't seem to find an updated list of the games that are actually properly compatible with Crossfire. One of them mentioned on the AMD site is Crysis 3, so I've been testing that this afternoon at around 3K resolution (the step down from full 4K, I can't remember the exact dimensions) with all settings on very high and it's pretty choppy to play, pretty much expected for ONE card. The second card doesn't even start, GPU-Z is showing the load at 0%.
I have enabled the Crossfire setting in the AMD control panel, even allowing it for games that don't have a crossfire profile so I can't understand why it's not engaging at all.
I am running the latest drivers and Windows 10 Home.
If anyone has any ideas I would very much appreciate it!
Thanks.
Heat
Thanks.
