https://www.strava.com/activities/408309144
Wee quick ride in the dark tonight. Colder than I realised with shorts on, thankfully had my long sleeve madison jersey on though!
Still don't feel comfortable on the bike, was going to fit a nago the other week but an £85 saddle still costs a fair amount at trade which I don't have. First thing I'll do is fit a shim under my left foot as I feel when I get my saddle height right for my right leg the left seems to have a dead spot where I'm over stretching a bit. Will see how I get on with that.
Saddle may well come next as I have to ride quite far forward on the nose when doing 20+ on the flat, I want to sit further back but the wider nose of the kappa makes me sit forward. Maybe I'm making it all up and I'm just ****e haha.
Anyone know anything about truing disc brakes?
My TRP HY/RD rub a crazy amount and it's a right pain, but I can't see how I can do a lot about it. It's making me think disc brakes really aren't worth the hassle.
Nah, he could have gone round the back of the bike. The car driver was waiting, so he'd have passed by in front of it just fine. I'm not talking about crossing the centre line, just going to the offside of the lane rather than the nearside.
Take out pads. Pushback caliper, put back pads. Loosen caliper bolts, apply brake tighten bolts whilst applied. Does the trick to recentre for me.
FT man of great knowledge. Got any recommendations for lumpy foam rollers. My normal one doesn't hurt when I use it anymore so presume I'm man enough to step up to a lumpy one.
It depends on what disc brakes you have. If you have dual-caliper ones (eg TRP Spyres), then it's just a case of:
1) Loosen post-mount bolts
2) Turn the barrel adjuster so that the brake is at it's tightest
3) Pull the brake lever so that the rotor is grabbed fully
4) Keep the lever pulled, tighten up the post-mount bolts
5) Now loosen the barrel adjuster until it doesn't rub
Super simple. Not sure if the HyRds have a barrel adjuster?
Generally speaking, it's cheaper to add them to your contents insurance or even buy a contents insurance policy purely to include your bikes on if you don't have one already.
Bikmo Plus seems to be the most reasonably priced of the specialist bike insurers though.
Edit: also double/triple check your policy exclusions. The most common one is your bike will need to be locked to an immovable object through the frame if it is not stored in your house or a garage attached to the house.
)Bikmo plus here (Let me know if you want a referral)
£20pcm for £4500 cover in and out of house, and the crucial one competition cover. If you're doing any racing a must imho. Seen way too many frames written off to race uninsured. Best I could find including all of that cover by a long shot
Never use the barrel adjuster on the HY/RDs unless you've got the retention screw screwed in.
Jan may be interested in taking the old set off you in a few months if you don't get rid .
Sounds annoying - Spyres can be dialled in using an in-line barrel adjuster no probs. Even the official documentation says to use the barrel adjuster
Hope the BR785's aren't annoying to maintain when they arrive - I've had it easy so far!
Sure, I planned to keep them for spares. So might as well go to a good home!
3'C on the commute today, not sure I'm going to get away wearing shorts for much longer!
I only just saw this sorry. You'll get better results asking in the Gym Rats or Icecold's Mobility thread. I just use the cheap MyProtein foam roller. I think unless you buy a decent one then you'll pretty much have to replace them fairly regularly after heavy use.
That said, if you've got a regular foam rolling routine it's pretty normal for it to hurt a little less. I'm guessing you've been foam rolling for ages though so it's not a "noob gains" kind of situation![]()
I'm only light too, so guessing that mine will last a bit longer than the beefcakes over in those threads.No problem, only posted late last night, will ask over there, use it few times a week, even my ITBs don't really cause me any pain anymore, and I've checked I'm doing it rightI'm only light too, so guessing that mine will last a bit longer than the beefcakes over in those threads.
That's pretty good. Does it cover you for any kind of riding in Europe? I'm paying not much less than that for 1600 worth of cover (just one bike) but it does include touring in the EU. Obviously I'm not racing too...
Worldwide cover, in transit and on location, whether competing or on holiday.
Cool, will depend on what I do for my TT build, are they 4 or 5 bolt?
