Fury x vs 980Ti
done ordered g1 :) thanks for help people how is the best way to uninstall the amd drivers etc never used nvidia for alongggggg time
Drivercleaner etc.
But as the chipset is also AMD you need to be careful, what you remove.
Me personally to avoid any issue would just do a clean install again.
Zotac AMP! is cheap, has good clock speeds, but it doesn't have a 0dB fan mode (where the fans don't spin when the card is below 60-ish C), but you can make a custom fan curve in MSI Afterburner which a lot of people do.
Zotac amp does have 0db up to 60c.
Mine iverclocks +220core +500 memory no voltage increase & has 5 years warranty and is amazingly quiet & cheap
weird thing is it says free items rainbow and assassin creed but when you hover mouse cursor over it it says claim one :? so shouldnt it be free item
I think his point is more that "Free items" is misleading, however I think that's just a collective term used by OcUK regardless of the quantity of free items you actually receive.
G1 gaming seems to be the best performance card where 1500+ is normal. I broke 1600 on a heaven run using the older F3 BIOS. You do need good airflow for the G1 though as it has no rear venting.
I think all cards can be made to run with fans off until a specified temperature via some BIOS editing if they don't support it by default.
Free items 1 game
Driver cd
Molex to pci e power
A box
Some bubble wrap
And maybe if ur super lucky a dvi to vga connector.
See brilliant value for money.
hey iv never done warranty on a gpu before how do i do that ?? i went to gigabyte site and it just says something about contact where i purchased it from lol ?
