Man of Honour
- 13 Nov 2009
- Northampton
Yellow stuffs work really well as you say but god they are dusty
Dust isnt really is an issue on a car that does 4k miles a year and is washed weekly
Well I've collected the car and run a couple of heat cycles through the brakes, far too early to make a judgement call on their quality. Brake feel is that of a car with brakes that need bedding in. Have another longer journey this afternoon so hopefully I will be closer to bedded in brakes then and can make a judgement. Discs look good though.
Question.
I have the car booked into Centre mavity next month (soonest he could fit it in!) for a full realignment as the garage felt that was out. I didn't want the factory settings on the car which they offered to put on as these are not as good as those I had. I am considering getting the car tightened up and lowered to remove the gaps above the wheels. What are peoples view on the best suspension for a Mk3.5 MX5? I am happy to pay proper money but I'd like to get dampers and springs replaced as we are keeping the car, hand them to Chris Franklin, fitted and then set up for road use.
Wife really loves the car so having decided to keep it I am getting stuff refreshed. I am also going to get the engine breathed on soon, but not going turbo, rather a more powerful NA engine with higher rev limit, with the associated rebuild and strengthening.
Best suspension, I'd go for the Ohlins Road and track coilover setup, the spring rates are pretty Road friendly. Speak to BLiNK again as they were doing a deal on supply and fit, 1400 plus vat for a full install with cornerweighting and alignment.
Lots of people rave about the Meister R offerings for the mk3, definitely the most popular option but the low speed ride is pretty crashy (these are what I have on my car), if I had to choose again I'd spend the extra and go for the Ohlins which ride better. The Meister R are simply okay I feel.
If you definitely don't want a coilover then see if bbr will let you drive a car running their custom spec koni damper and custom wound spring setup, less faff with getting them installed than any coilover and about a grand plus vat fully fitted.
Using those engines seem like a strange solution. The MX5 bottom end is good for 250bhp on standard internals.
Yes and the Saab units are good for about 500 and are pocket change to buy.
No different to engine swapping any other car, why so negative about it?
