ipa will loosen the adhesive,then floss away
I checked my voltage and it was max 1.15v under real bench at stock clocks of 3.9ghz.
A rice grain sized drop is all you need.I will take cooler apart tomorrow and take a picture of how much I used. I used small pea blob in the middle.
C2d chips were soldered, its only since Ivybridge that Intel have started pasting mainstream chips.Has the de-lid technique changed much since the core 2 duo days?
You can pick them up for pennies now, why not experiment with these first?
Okay so is there any way to soften the silicon or whatever its holding ihs ? I tried with hairdryer just now on e7300 2minutes 20 cm away from chip, but when I try to do with dental floss it doesnt want to go through and I dont want to be to hard as my fingers are already red![]()
Just get a hammer and hit it, it's not difficult.
Did you see the vide in my linked post?
What thermal paste did you use on the cpu die?Hmmm, i delided my i7-4770K back when i got it 2 years ago or so, had it stable and OC it to 4.2 and never really worried about it again. But just got Overwatch over the last week and that has an option to show system info in game and noticed that the temps while gaming on Overwatch was around 72c and thats with it delided!!...thats seems high no?
Might need a clean and reapplication.
