now that looks good and is the best alternative to the D-Frame
what i love
1..... the GPU mounts sideways so you can see it's underside, e.g a 980TI Lightning will look awesome
2..... enough room for a Megahalems
3......after looking at it more closely, normal cooling fans will fit on the right hand side ( good cooling)
4......miles cheaper than D Frame
they moan about the Dust , but it's not exactly hard to shift is it, you simply blast it with a hair dryer.
but :- you'll need to get a piece of glass for the front, because those plastic side windows are useless.... just take the plastic to a glass shop and tell him to remake it out of 6mm, it might cost you about 35 quid
