Thermaltake Core P5 ATX Open Frame PC
Interesting looking case.
I'd consider it but I need space for at least 6 HDD's.
Its very nice indeed! you could install three on the back and one on the front and then I suppose you could 3d print some more drive bays for the other ones and install them on the rear also :)
But the link to the 3d files is not working yet Oh well
I think is down for release in USA today at $150 dollars so we see not being robbed as much as we usually are!
Hopefully not far away here, only downside is that I think it's a plastic window not glass. I guess that keeps the cost down?
You could always get a tempered glass one made :)
now that looks good and is the best alternative to the D-Frame
what i love
1..... the GPU mounts sideways so you can see it's underside, e.g a 980TI Lightning will look awesome
2..... enough room for a Megahalems
3......after looking at it more closely, normal cooling fans will fit on the right hand side ( good cooling)
4......miles cheaper than D Frame
they moan about the Dust , but it's not exactly hard to shift is it, you simply blast it with a hair dryer.
but :- you'll need to get a piece of glass for the front, because those plastic side windows are useless.... just take the plastic to a glass shop and tell him to remake it out of 6mm, it might cost you about 35 quid
